corradoman93 0 Posted May 2, 2012 Hi, I am thinking of getting a b4 passat tdi gearbox I think the code is t4. Will it fit my Corrado 2.0-16v? I want the longer drive in 5th, do I need to do anything else, will the Corrado starter fit the tdi gearbox, and will the Corrado drives match up tdi gearbox? Thanks Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 2, 2012 An 02a gearbox will just bolt up, but the ratios on a tdi box won't suit the 16v engine, a 5th gear swap would be a better mod. See yandards guide. Quote Share this post Link to post Share on other sites
dannyboy 0 Posted May 2, 2012 i would agree with dave there,you need to be look at higher torque engine before swapping gearboxes.You'll lose all accelaration and your car will feel flat as a pancake and not as fun to drive.But if you want to then by all means try it. Never heard of a T4 gearbox,heard of a T4 vw bus though.All gearboxes have three letter prefixes like ASD,CTN,ATA,ATB. Depending on the box depends on the gearing.... Quote Share this post Link to post Share on other sites
corradoman93 0 Posted May 3, 2012 Yes Its a CGY gearbox from a golf mk3 I think. Where do I find that thread u were saying about removing 5th gear? Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 3, 2012 Yes Its a CGY gearbox from a golf mk3 I think. Where do I find that thread u were saying about removing 5th gear? in the wiki: http://wiki.the-corrado.net/5th_gear_cog_change.html Quote Share this post Link to post Share on other sites
