mattyattitude
strange noise while driving.
ive recenetly developed a strange noise.
it only seems to happen when driving above 25mph and gets to a set volume and then doesnt get any louder regardless of speed. its not engine noise cause i can drop it out of gear and it will still continue. its not offected by turning as far as i can tell its just there.
Only way i can describe it is its the same sorta noise your exhaust makes but at a different pitch. that low sorta grown.
i thought it might have been the wheel bearing at first so ive changed that and its still there.
anyone got any ideas????
It could still be a wheel bearing? Are you sure you changed the right one? :)
tyres, I've had some old ones that make a hell of a racket, sound similar to a badly worn bearing.
i was thinking that jim,lol!!
if it not engine load dependent,got to be suspension or bearings as jim said.Id also look for vibration caused by loose trim,i can play havoc trying to find that annoying noise. Ive got vibration through the chassis,turns out to be the one of the intercooler cushion pads i made has left the building and IC vibrates through the rad support
