Rich_T
Drivers Side Outer Door Handle - Wanted
As the title, Im after a drivers side exterior door handle, I dont need the barrel but if the barrel is still in place I would need the key to suit.
Replied, however without the key the old barrel wont come out, so its not really any good.
You can pick them without much bother. I didn't have the key for one of mine, it's really easy when you have access to both sides!
Remove the circlip and the V-shaped metal part that engages with the door lock, then stick two hairpins or similar down the outside of the barrel from the back, one from each side and in line with the key slot. Once you have all the wafers pushed from the outer section into the keyway you just push from the back and the barrel will fall out. Simples :)
Stone
