fla
wear-resistant piping fpr aircon pipes/oil cooler pipes
Can anyone suggest any piping oversheath to be used on aircon and oil cooler pipes to prevent the rubber chafing and wearing against the rad fan shroud? I'm thinking of something along the lines of a 'cable tidy' tube, but I dont believe this would be sufficiently resistant to heat.
I'm currently using foam pipe insulation which works but is very bulk and makes the limited access even more restrictive.
Thanks
