Peebee
ABS staying on.
Ever since the 24v conversion went in the ABS light always comes on as soon as i pull off, not on start up! I have ignored it for for a long tine but i should look into it. Any thoughts on what it could be, im fully aware that Corrados are prone to ABS issues but dont know the ins and outs.
Thank you in advance,
Paul.
If it comes on as you pull off, it's a wheel sensor - a physical issue. So you're either missing a sensor ring on the hub, or a sensor isn't positioned right. If it comes on as you pass 10 kph (exactly 10 kph) then you have a valve problem in the ABS control block in the engine bay. A VAG-COM scan will confirm which ..
If it's the valve block chances are it's not fixable and you'll need to replace it. You should be able to pick one up used for not much cash if you need to. I think I paid £20 for mine .. !
