KBN-STANCED
Corrado g60 issues after fittings 68mm pulley and Jabba chip
Having issues with my corrado after fitting the above items it also has an rsr fitted and a full stainless manifold and exhaust system basic I'm getting white smoke (which I know is a sign of unburnt fuel) and also getting loud poppin and banging with the occasional flame out the exhaust any help would be much appreciated cheers Kieran
check you ecu vac hose,might not have been reconnected properly.youll get massive overfuelling on overrun and WOT
When I first got my G60 it had a Jabba chip and overfuelled badly (which was an issue with them then - this was 7 years ago). Replaced with an SNS chip, everything was fine.
