rossb
ISV power. Help needed
Hi I'm looking for some help/advise.
My 91 g60 seems to have developed an intermittent fault with the power running to the isv, i think it's a problem with the black/yell stripe cable sometimes getting power then other times no power resulting in the engine cutting out or not starting.
When I connect a permanent live to the isv bk/yell cable the car runs fine but obviously will not switch off with the ignition.
I've changed the ignition sw with a new genuine part and that has not helped.
I think it might be a relay but witch one?
Any help or advice would be great as the MOT is next week and I need to sort it.
I have a 30 relay in slot 3 on the fuse board is this the one as I've just been quoted over £50 for that one at motorserv.
Part number 165 906 381
He also said it was the fuel pump relay which seems wrong.
