Henny
Changing power steering fluid
Right, I've had to take the power steering pump out of my car while I did my rebuild, so obviously it's dropped it's fluid (into a neatly placed container of course! ;) )
What's the correct way of re-filling the system, as I know I don't want to run it dry and knacker the pump and the rack???
Anyone know?
i usually fill up the system with the engine off.....then prime it by disconnecting the hal sender and turn it over for a few minutes....usually there is bubbles and a drop in the fluid level...
U probably wont get all the air out untill u run it
HTH
if different, let me know how u actually do it - incase i've got it all wrong!
I've just done it by hand so far... No P/S belt on, top up the fluid to the max, and then sit and turn the pulley by hand for a few minutes.. then lock her over side to side, and turn it some more...
..seems to have worked so far... Guess I'll find out when I try and start her when I get a starter motor that works... :roll:
