teveO
65mm/68mm pully and chip suggestions please?
hi guys
i have a corrado g60 and the engine is pretty standard i have carried out the boost return delete, changed the plugs and leads etc...
i was wondering the best ways to increase power? chip and pully is looking a good option? any help would be awsome.
cheers in advance
steve.
68mm pulley with matching chip is the most common upgrade.get the correct one.if you get a rubbish one your car will run like crap,use too much fuel and horrible to drive.
Dont even know the one i had,but it ran extremely well and no increase in fuel compusmion
Dont bother going 65mm if you've not done loads of other mods. 68 and chip (ideally SNS) would be the way to go at the moment.
If you're going down the boost return delete (which to be honest I wouldn;t bother doing after having tried it in the past) make sure you get some of the correct spray lubricant for the charger.
