vwnutter 10 Posted July 24, 2012 hi all im not sure if this is the right section but thought id ask, i had an immobiler on my Rado vr6 that was basically crap. i have removed it now but since removing it i had a few issues with the car starting. anyhow it now turns over and starts fine although i think my ignition barrel is on its way out. my issue is that all lights on dash from turning key in ignition have now dissapered. all instuments on dash are not working either? fuel speedo temp etc? what should I be looking for as its been 3 days now and im fed up of unwinding insulate tape! all help welcome and thanks in advance Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 24, 2012 Have a good look for all earths that may have been removed whilst removing the immobiliser. If they're all at points, ensure they're nice and tight. Quote Share this post Link to post Share on other sites
20vtvw 0 Posted July 27, 2012 check plug e2 is live if not it needs a jumper lead to it..(black wire at top of fusebox)hope this helps Quote Share this post Link to post Share on other sites
dumptyboy 0 Posted July 28, 2012 As 20vtvw says; there will be a black wire from plug e2 that is about 6 inches in length and goes to a junction block, it is likely this has been pulled out by accident and needs refitting. Drop the fuseboard down and trace this cable. Quote Share this post Link to post Share on other sites
