AJ_EQ
Crank position Sensor - 021 906 433A
As per title, I'm after a crank position sensor, as I believe mine has gone kaputt. Car continually turns over but doesn't fire. No AC and RPM through the fuse. Has happened before and car started the next day after it had cooled.
Does anyone have a low mileage complete functioning one lying around?
A friend in the unit next door has just broke to Golf VR6 engines, assuming they are the same he should at least have one spare.
Want me to enquire..?
check your ecu relay no 109 first - its about £12 from the dealers. This will allow the engine to crank but will stop the injectors opening (and also prevent it from sparking iirc???) so your car wont start.
