VW Corrado 16V 0 Posted August 7, 2012 I have two questions about deleting the ABS brake system from the Corrado (16v kr) 1. Can I use the Servo (brakes) from Passat B3 1.8 i or Diesel? Is it the same as the Corrado Servo ones (originally without ABS Teves) ? 2. After installing the Servo, can I use directly the 25 mm master cylinder and put Girling g60 front brakes. Can I use the standart 3 lines (2 front + 1 rear) with this setup brakes? thanks Quote Share this post Link to post Share on other sites
STU175 0 Posted August 7, 2012 (edited) i have some audi s2 calipers to fit and found this info quite helpful. still havnt got round to it yet tho or found a source for the 25mm brake master cylinder so if you have any luck let me know:thumbleft: http://www.myturbodiesel.com/1000q/a3b4/girling-g60-brake-caliper-swap.htm Edited August 7, 2012 by STU175 Quote Share this post Link to post Share on other sites
