crookiecrook 10 Posted August 23, 2012 i brought a rsr kit because i wanted the louder noise from the supercharger, but after fitting it, it hasn't made any different what so ever, any ideas? do i need anything else? Quote Share this post Link to post Share on other sites
floppyman 0 Posted August 23, 2012 ?!?!?!? Thats strange... Did you remove the big black box from the right side of the charger? Quote Share this post Link to post Share on other sites
crookiecrook 10 Posted August 23, 2012 yes mate Quote Share this post Link to post Share on other sites
floppyman 0 Posted August 23, 2012 :screwy: i have no ideia whats happening there then Quote Share this post Link to post Share on other sites
owen g60 10 Posted August 24, 2012 Have you taken the snorkel off the front of the air box this makes a big difference Quote Share this post Link to post Share on other sites
crookiecrook 10 Posted August 24, 2012 its got a jabbasport induction kit on it Quote Share this post Link to post Share on other sites
owen g60 10 Posted August 24, 2012 hmmm i have no idea then you should get a similar sound to mine. this was taken last week on the rollers... has a twin inlet airbox and golf 180 bend on it when it gets over the fan noise you appreciate how loud it is Quote Share this post Link to post Share on other sites
crookiecrook 10 Posted August 24, 2012 well i'm looking at buying a twin inlet k&n kit for it, but i didnt no what to do with the return piper that goes to the throttle body, plus i wanna see if it make any different with the noise Quote Share this post Link to post Share on other sites
jaded2882 0 Posted August 27, 2012 If you delete the boost return it will change the noise a lot. You can get kits off ebay and the best ones vent the air from the bottom of the tb into the engine bay, but vent the OIL back into the side of the charger. That way you get the noise from the air escaping, but retain the oil to lube the charger. Having said that, you can get the simpler kit that vents both and just periodically lube the charger with PTFE spray. Don't bother with the twin kits, it doesn't change the noise much and won't improve power. Put a K+N filter in the airbox and drill the bottom if you don't mind the damage! Quote Share this post Link to post Share on other sites
crookiecrook 10 Posted August 29, 2012 cheers mate, what are these kit called so i can get it, well ill prob sell on the twin kit on lol Quote Share this post Link to post Share on other sites
jaded2882 0 Posted August 30, 2012 http://www.ebay.co.uk/itm/S2-VW-CORRADO-GOLF-G60-DUMP-VALVE-KIT-/140835013027 Ignore the description as 1, it isn't a dump valve and 2, it doesn't change performance... The charger runs much cooler with it done though. I also put a little air filter where the boost was venting into the bay as it stops the nasty half throttle whistle. Quote Share this post Link to post Share on other sites
