lewvw
Very sharp stall/bang intermittently
Intermittently when gently accelerating 2nd/3rd gear 20-35mph my car will feel like it has hit a brick wall which usually stalls the engine, for the first time today it did not stall though. This happens maybe once a week if that. Any ideas guys?
Is your car automatic Lewis ? If so poss torque converter or box fault ?
Just re-read post-assume it manual !
Edited by Harrier
Well it happened again today on tesco roundabout quedgeley in rush hour and nearly got me shunted and written off :( so I had a quick look under bonnet wiggling all engine related terminals and found my crank sensor wiring just sitting on the front crossmember
[ATTACH=CONFIG]69564[/ATTACH]
Gave it a quick wiggle and sure enough it killed the engine instantly, further inspection revealed the engine loom side has rubbed through and corroded. A wiring repair is in order :)
At least it was easy to find and a cheap repair.
