nickeboy 0 Posted October 12, 2012 Can anyone scan me a copy of the Bentley manual for pretensioning the rear bushes, I have page 42.2 42.3 but not the bit about how to do this I'm tackling it tomorrow so much appreciated Thanks Quote Share this post Link to post Share on other sites
aide 0 Posted October 12, 2012 if you haven't moved the beam brackets, then you'll find you have to lever the trailing arm into the brackets, that's what i had to do and thats what I understand as 'pretensioning' the beam. Quote Share this post Link to post Share on other sites
Chrisvw419 0 Posted October 12, 2012 If this is you Nick, Mark is borrowing my manual tomorrow to bring with him, should give you everything you need. Quote Share this post Link to post Share on other sites
nickeboy 0 Posted October 13, 2012 It it, he has, thank for that Nick Quote Share this post Link to post Share on other sites
aide 0 Posted October 13, 2012 The Bentley does not say how to pretension only that you should. It does say as noted above, insert right side then lever in left side, there's really no need to get over complicated or concerned! Quote Share this post Link to post Share on other sites
Chrisvw419 0 Posted October 13, 2012 The Bentley manual clearly shows the procedure for the pre-tension with diagrams, as does the Lindsay manual, I double checked before lending him it. Its not complicated as said, but slightly more involved than stated above Quote Share this post Link to post Share on other sites
aide 0 Posted October 13, 2012 I must have missed it, can you describe exactly what's involved then? Quote Share this post Link to post Share on other sites
