PhatVR6
Power steering fluid "oil cooler"
Just looking at the way the pipe comes through the front rad support. anyone been tempted to stick a cooler in the pipe?
My exhaust runs damn close to the steering rack you see, and tends to boil the fluid sometimes.
I thought it already was acting as an oil cooler by being routed that way by VW? It's in the airflow.
My old Bimmer had a kettle element shaped PAS pipe which slowed the fluid down enough to be cooled by airflow. That's about all you can do really as I've never seen a 'mocal' type PAS cooler before, must be a reason for that. Probably can't take the pressure, risk of air locks, slows the flow down too much etc etc.
How about lengthening the pipe & re-routing it back accross the front of the car behind the bumper air ducts ?
Larger pipe surface area = more cooling ?
