Tjninny 10 Posted November 3, 2012 Hi, Can anyone tell me the spec for the banjo bolts needed to fit Golf MK3 16v calipers to 288mm discs? I think that they are M10 but certain of thread or length. Thanks. Quote Share this post Link to post Share on other sites
daleyboy 0 Posted November 3, 2012 Mk3 16v calipers ? I have Golf mk3 vr6 calipers which fit the 288mm disks, is that what you meant ? Quote Share this post Link to post Share on other sites
swampy 0 Posted November 3, 2012 Yes the fronts are an m10 x 1 thread you want a length from bottom of head to tip of bolt of around 22mm Quote Share this post Link to post Share on other sites
daleyboy 0 Posted November 3, 2012 Swampy i thought there could be two thread depths (1mm and 1.5mm) depending on the source vehicle ? Quote Share this post Link to post Share on other sites
swampy 0 Posted November 3, 2012 Afaik they are 1mm though they could use both, Quote Share this post Link to post Share on other sites
Tjninny 10 Posted November 3, 2012 Yes the fronts are an m10 x 1 thread you want a length from bottom of head to tip of bolt of around 22mm Cheers Swampy, That's great. Quote Share this post Link to post Share on other sites
Stonejag 10 Posted November 3, 2012 Afaik they are 1mm though they could use both, I've see both types...nothing for it but to give it a go, if you can get more than 1 thread in then you have the right type! Stone Quote Share this post Link to post Share on other sites
