joebrent
Strange noise
Sometimes when i go to start the car i get a strange grinding,sucking noise?? The sound seems to come from the rear of the car i think? It usually only happens when i try to start the car while giving it some throttle. When i get this noise it usually takes about three attempts to get it started normally. Apart from this all is perfect 8)
Any help very much appreciated, cheers guys :!:
probably time to change the fuel filter and see if that cures it... ;) 8)
change the filter first, they're about a tenner and aren't massively difficult to change... 8) If that doesn't help matters, then it's time to start looking at the more expensive things (pump is around the £100 mark)
yup... A blocked fuel filter will starve the engine of fuel and make starting difficult, as well as possibly making the engine run lean at all times... :?
Lots of potential hassles, all 'cos of a £7 filter... :? :roll:
