Hofmiester 10 Posted November 10, 2012 The VR has a bit of a notchy gear change in 1-2nd when cold, no crunch but you can feel somthing not going into place smoothly. I remember that I changed the gear oil in my 16v ages ago and that improved things but can't remember the oil type, does anyone here know? I also remember that I had the cables adjusted at a garage and that also improved things but my guess is thati could do this myself. Are there any good DIY tips? Thanks Ron Quote Share this post Link to post Share on other sites
Portent 0 Posted November 10, 2012 Also worth noting that my gearchange improved a lot after I replaced all 3 of my tired old engine mounts. Quote Share this post Link to post Share on other sites
dragon green 6 Posted November 10, 2012 Redline MT90, And one of Daves16v short shifter kits,they really make changing gear a delight ! Quote Share this post Link to post Share on other sites
daleyboy 0 Posted November 11, 2012 Although i wouldn't disagree with Dragon Green, i had the same problem as you the 1-2 shift just didnt feel right, new engine mounts did cure it. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted November 11, 2012 The car has a vibratechnics upfront and has had the other mounts done this year. The problems stops as soon as the box is warm which suggests it is a problem with the box? We are talking really subtle, totally livable but would be nice to fix. Quote Share this post Link to post Share on other sites
daleyboy 0 Posted November 11, 2012 I think its just the way the car is, mine tended to snatch into second with a mild crunch if i was too quick, is that what you mean ? Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted November 11, 2012 I think its just the way the car is, mine tended to snatch into second with a mild crunch if i was too quick, is that what you mean ? yeah that sounds right, when the car is cold, if you change too quick from 1-2 then there is a bit of notchy-ness, not a crunch but you can tell somthing isn't mechanically ready :) All fine after 10 mins driving Quote Share this post Link to post Share on other sites
daleyboy 0 Posted November 11, 2012 It could be just the cables are a bit stiff and when the engine bay heats up they free off a bit. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted December 9, 2012 Sorted this today, cleaned and greased the linkages at the gearbox end and at the selector mech. Feels like a new car now! Quote Share this post Link to post Share on other sites
Abdul 0 Posted December 9, 2012 Can't beat an easy fix especially on a rado! If you haven't already changed your engine mounts its another thing I'd defnately advice looking into. Improves the car so much in every aspect IMO if the old ones are tired. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted December 9, 2012 Yep, mounts have been done so it feels spot on now.....better than my wife's 61 reg Fabia! Quote Share this post Link to post Share on other sites
