Barney 10 Posted November 13, 2012 Ok here goes after months of going round in circles with my Corrado 9a I'm having a new problem which I Am going to have too ask for help with! Car will start and run cold it will idle fine for a few minutes without a problem! Then it will stall at which point it will not start or even attempt to start. Now I've found the only way I can then get it to start is too unplug the temp sensor for the ecu, at which point it will start but you have to hold it on the throttle or it will stall. Ok sorry if it was long winded but any help would be greatly appreciated I've replaced the temp sensor to ecu, idle control valve, metering head, Quote Share this post Link to post Share on other sites
tony_ack 0 Posted November 14, 2012 Check the wiring between the temp senders, idle valve, thermotime switch and the cold start injector. Quote Share this post Link to post Share on other sites
