emu
Blackberry VR6 for £1850 in Aberdeen
VR6 | Blackberry | Aberdeen
Price: £1850
Description:
Its priced to sell, if wont I will brake it on parts. Price is not negotiable, This car is worth more in parts, already broken 2 Corrado and will do this again no problem.
1994 M reg Blackberry Corrado VR6
Registered 31-08-1994
Around 160k miles, need to double check it
MOT ends May or June 2013
Tax ends Dec 2012
Work done
May 2010 – MK4 Rear brake calipers and OS handbrake cable
Oct 2009 - Rear engine mount, Schimmel 263 cams, new spark plugs, coil pack, clutch, some sundry items and remap to suit with printouts.
Aug 2009 - New genuine VAG oil pump
June 2009 - New chains, tensioners and guides, head reconditioned by Allstage, new valve guides, new tappets, new senders, seals, clutch, thermostat housing and many other little bits.
March 2009 - New Battery
May 2008 - Front engine mount and most of the cooling system, heater matrix, radiator, water pump, aux water pump, thermostat, thermostat housing, all the sensors and a few of the pipes.
July 2007 - New leads
March/April 2007 - Koni top adjustable dampers, H&R springs, Powerflex front suspension bushes, new suspension arms, 288mm front brakes with Greenstuff pads & drilled/grooved discs. 4 x Original Speedline wheels professionally refurbished
March 2006 - New rear discs/pads/bearings for the MOT and a replacement indictor stalk
Mods
- Remap with printout on circa 210 PS, need to find a graph, done by Stealth Racing
- Complete, clean and reconditioned Beige heated leather interior, driver seat has some marks, still have paint left so can be easy fixed, just have no time to do this, but leather paint will be included in sale
- Schimmel 263 cams
- Top adjustable Koni shocks + H&R springs
- Powerflex front suspension bushes
- 288mm front brakes with Greenstuff pads & drilled/grooved discs
- MK4 rear brake calippers
- Milltek stainless exhaust system
- Lupo GTI wiper conversion
- Headlight loom upgrade.
- Air conditioning
- Thatcham 1 Laserline
- Momo millennium steering wheel
PLEASE NOT. Number plate is not included in sale, Audioscape door pods can be left for 100 quid extra or back to standard ones, rear strut brace 50 quid extra or will be removed, DDI clocks 100 quid extra or back to standard ones.
BAD POINTS. Car had a bad respray in the pas and paint is in very bad condition, basically whole car needs respray, dent on passengers and drivers doors, small rust on driver side front wing. Engine use 1L of oil every 4k miles.
PLEASE NOT. BIG DENT ON DRIVERS DOOR VISIBLE ON PICTURES HAS BEEN PULLED OUT BUT THERE IS STILL VISIBLE SMALL MARK, REAR PARCEL SHELVE AND SUPPORTS BEEN REFITTED NOW.
Edited by emu
