vw_john
engine mounts
Easy to replace. Undo the top bolt in the middle. Undo the two smaller bolts either side. Jack up gearbox. Remove. Refit.
You can get a new one from VW. Worth getting a solid MK2 golf mount instead, rather than a Corrado hydro one.
Thanks! I'll give my local VW a call tomorrow for the solid MK2 mount, is it the one from a 1.3 driver? I think I read that somewhere?
