Corradovr
Engine fault code
Hi all , my corrado vr6 has suddenly started running lumpy abit like a misfire but not spark fault more like a fuel fault I plugged in my fault code reader and got a code 561 fuel mixture control . Has anyone got any ideas what could cause this , maybe maf or lambda ? anyone suffered with this ?
Guess you should find some info here:
http://wiki.ross-tech.com/wiki/index.php/00561
Or to save your trouble:
00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
Possible Symptoms
Engine Jolting
Increased Fuel Consumption
Poor Idling/Jolting
Reduced Boost Pressure
Possible Causes
Mass Air Flow Sensor (G70) faulty
Fuel Pressure too Low
Leaks in Intake Air System and/or Exhaust System
Injector(s) faulty (i.e. coked)
Possible Solutions
Refuel Vehicle
Check Fuel System Pressure
Check Mass Air Flow Sensor (G70)
Check Intake Air System and Exhaust System for Leaks
Check Injection Quantity
Check Injector(s)
Thanks pal massive help , I had a inclin it was my maf because over the last year I had changed most bushes , coil ect. As I like a care free drive, I will test it today . Can't get over how good this forum is,by far the best I have been on it's instant response of vr6 knowledge, great thanks again .
---------- Post added at 6:57 AM ---------- Previous post was at 6:42 AM ----------
Hi mawrick , would you happen to know what range of resistance Ishould get when checking maf sensor to know if it I working as it should thanks
Thanks for all the help I do think it is mass air flow I unplugged it and cleaned it at weekend . I forgot to plug wires back In I took I for a drive a all faults were there . Plugged back in and a tad better but rough idle still there. Does anyone know if my part number being 021906462 no letter would be interchangeable with 021906462a as I can get one for 25 quid thanks g
