vw.classics 0 Posted December 11, 2012 I've been getting a few issues recently with what seems like a bad earth, I think... Sometimes, when I brake the indicator lights will start to light up on the dashboard. Also, when I indicate left sometimes the left indicator will stop flashing consistently. Any thoughts / ideas on what to check? Cheers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 11, 2012 Most likely you have a blown / incorrect or badly fitted bulb... Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted December 12, 2012 i had something similar on my old mk3 golf, if you were indicateing and you braked the indicators would stop ,if you did that with the headlights on the indicators would reverse themselfs, turned out to the passenger rear light connections were corroded. Quote Share this post Link to post Share on other sites
vw.classics 0 Posted December 12, 2012 Most likely you have a blown / incorrect or badly fitted bulb... I replaced both the rear side / brake light bulbs and problem cured!! Glad it was a nice and simple fix. Thanks for the advice! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 12, 2012 Cool, that's what you need inn this weather! Quote Share this post Link to post Share on other sites
captainredeye 0 Posted December 12, 2012 i had this but only when my headlight were on, fitted an uprated loom and the problem went. Quote Share this post Link to post Share on other sites
josh.c 10 Posted December 13, 2012 i had something similar on my old mk3 golf, if you were indicateing and you braked the indicators would stop ,if you did that with the headlights on the indicators would reverse themselfs, turned out to the passenger rear light connections were corroded. +1 for me on the rado. Rear offside light connections were corroded. Happened on the day of the MOT as well which is a bit sods law. Easy fix though :thumbleft: Quote Share this post Link to post Share on other sites
lard44 0 Posted February 3, 2013 I've just bought the OP's car yesterday and today the fault has reoccurred...rear lights double flashing instead of indicators, brake working the dash display, all very bizarre. Glad I used the search function as it means I'm not starting from scratch...will investigate later and report back... Quote Share this post Link to post Share on other sites
