Jim Bowen
Strong Smell of petrol near front of car
Have noticed a petrol smell at the front of car when stood near it/washing it etc.
Its right by the carbon canister thing (VR6 engine) Is it normal? not used car for 18 months so can't remember if it smelt before.
I recently replaced the fuel lines on side of engine and don't think its these. Does the carbon cannister wear out or need replacing?
Carbon canister should purge all fuel vapour with the engine running.
When the engine is not running it is suppost to store fuel vapour.
As you have been changing a fuel line in that area I would check those first and anything else you way have caught or moved during this as it is more likely that this is the source of the petrol smell.
Will have another sniff around then, am sure the bits i did smelt less than the bits going to carbon cannister.
