Smiithy
OBD1 or OBD2?
Firstly sorry if this is in the wrong section.
Im just wondering if somebody could tell me if my 2l 16v 9a rado is obd1 or 2? and where the plug is located.
Thanks
Sweet thanks mate.
Dose VCDS (used it on my old PD130 bora) work if i get an obd1 cable to read fault codes (if any) and to log lambda's etc?
No idea mate, you might find it has a later plug? But it's fairly limited for testing as far as I'm aware. Hold tight and someone with the correct knowledge will be along to help :)
