G60radoboi
Indicator stalk does not return to position.
Not too sure if it is because of the aftermarket steering wheel on there but the indicator stalk does not click back to the neutral position. Will refitting an OE steering wheel and boss sort this issue?
It could be the stalk but its equally likely to be the aftermarket wheel. When bought my car it had a momo wheel and boss and did the same as you describe. On the advice of someone here it turns out that the boss has to be fitted the right way up. If it doesn't then the indicator won't return correctly.
Mine has never returned since I've owned the car (standard wheel). I like it that way :p
