owen g60
What pads to use?
I've just changed my calipers and wanted to do my pads at the same time.
I have grooved and drilled disks, I went to fit oem pads but they are too wide and couldn't get the calipers on the disk even with the piston wound right back in.
What car / brake setup have you got???
---------- Post added at 8:35 PM ---------- Previous post was at 8:34 PM ----------
If it's a G60 then I think you might have fitted 16V calipers to it!
They're g60 calipers.
I'm beginning to think I've got pads for the thinner disk/calipers combination
---------- Post added at 9:18 PM ---------- Previous post was at 8:39 PM ----------
What width are standard g60 disks?
I know they should all be 280mm as mine are, I get the feeling mine are wider as they're drilled grooved and vented.
Could be wrong here
