bigbaz
info on this sensor pic added
hi can anyone tell me what this sensor is please the 1 that is threaded in by the fuel pressure reg as the wire has broke of it[ATTACH=CONFIG]72673[/ATTACH]
ok cheers for that not a problem then
That depends on if you want your G60 to work or not.
All the early Corrado engines have a similar sensor used for coolant fan run on, they also run the fuel pump on the G60 to prevent fuel vapourisation issues as well.
So I would recommend you have one or your coolant fan won't run when you turn the car off.
Cheers where's best to get one from
