sankysvr6
Headlight Switch
Just a quick question.
The green light on my head light switch comes on, when i put my side lights on. (one click)
But then goes off when i put my dipped beams on (two clicks)
Is this normal, or is there something wrong with my headlight switch.
What a daft idea.
Well i will see if i can change it so it stays on in both potions, when i i fit the fuse at the back of the switch
The remanufactured group-buy ones from this forum keep the light on in both positions, much more sensible! (also you don't need the fuse...) Not sure if there were leftovers but plenty of people have them, could try a post in the Wanted section.
Stone
My understanding you will still need the inline fuse also for the remanufactured group buy one. There was a reason for this. It was discussed in the headlight switch thread before Iam sure.
last night when I switched my headlights on the green illumination failed to light . Up till then it illuminated on side lights and dipped beam which sudgests its a group buy re manufactured any ideas why it now dosn,t illuminate ?
