tinsman 0 Posted May 3, 2004 hey, im not sure if this is the right place for this post but ill give it a shot. ive had a air fuel ratio gauge by autometer for quite sometime and i still dont have the thing hooked up mainly becuase i done know how to do it. ive heard it was pretty hard to do. if someone could give me directions that would be awesome. thanks - tj Quote Share this post Link to post Share on other sites
Henny 0 Posted May 3, 2004 wire in the +ve to an ignition live, the -ve to a good earth, and the signal wire to the purple wire from the lambda sensor. The purple wire is at the back of the engine on the left hand side as you look from the front of the car... I found a picture on http://sam.bytebandits.com/radotutorial/ that may be of some use... 8) Quote Share this post Link to post Share on other sites
tinsman 0 Posted May 3, 2004 sorry if this sounds stupid.. but how do i ground the one wire? im not sure i understand? Quote Share this post Link to post Share on other sites
Henny 0 Posted May 3, 2004 attach it to a -ve wire in the car... they're normally brown with no other colours on 'em in a Corrado... you could also attach it to the bodywork somewhere as that will be connected to the battery's -ve contact too... :) Quote Share this post Link to post Share on other sites
