robrado974
Rear exhaust bracket
I'm a bit unsure we are talking about the same thing as the rubber is not removable from the bracket. Here is a pic of the mounts from the exhaust, top 2 are off the rear section, bottom off the middle box. Any of these what you are after?
As above, on the rear ones you cannot remove the rear rubbers as the pin is welded in place. I don't think you can buy from main dealers. I think they are about £25 each from VW heritage!!
I had my 2 mounts split at work, shot blasted new genuine rubbers fitted, re-welded and fresh zinc plated. I then found I only needed 1 as my supersprint comes with a different rear bracket.
Long winded but for sale if you are interested? I need to get the platers to re-dip it as it is going a bit funny at one side.
Would be £15 posted though as the genuine rubber was £5.
Can email a picture if you want.
Hi chris ,will take it thanks very much . Chaos3oe thanks for your offer but i need one thats in good nick .
Rob
Hi Rob,
No probs, dropped the hanger in today for re-plating and will pick it up tomorrow so good as new!
How do you want to pay please?
Chris
