seanl82
Handbrake cable splitter thing..........
Anyone know what this is called so I can order/search for a new one.
(Or have one lying around they don't need..............)
Thanks!
Edited by seanl82
I'm not sure if its exactly the same, but the MK3 Golf and 6n Polo handbrake is very similar to that. So you should be able to get that part of those, if you can't get it off another corrado.
Above mentioned way is also good to find but if you go to a experienced mechanic so he can tell you easily which part is this and this will save your time and energy.
Except for the fact the mechanic will charge me a minimum labour charge of an hour for removing the handbrake tunnel, and fitting a little piece of metal that would take about 2 minutes! I'm sure I'll survive doing it myself, but thanks Kev.
