borders16v
Alternator failed today,worn brushes.Where to find new ones? Thanks.
Well, met the AA man at the side of the road today. Complete electric fail and the brushes are well worn.The guy had a lucas part with the brushes on and said I need one and possibly a new alternator. As im skint right now i was hoping to replace the brushes but cant find any.
Can anyone point me in the right direction ?
Or suggest a cheap sopplier for new alternator, thanks guys.
When I thought mine had died on the valver, I managed to find a set of brushes on ebay of all places! You'll need the serial number of your alternator iirc, to ensure the type of brushes will fit. There was only one set though, and I looked back a couple of days later, and it was gone. Lucky for me it was just a large earth and I managed to get to the bottom of it!
What car do you have?
A brush pack is £10 from any decent Auto-electric place or geniune from VW is about £25 and usually much better quality too
That looks correct but check the voltage - some of the ones supplied by GSF etc are not right and you have to blip the throttle to get the light to go out.
If it's just worn bushes then you could get new ones soldered into your existing pack - cost pennies!
Edited by davidwort
Did you buy a new regulator and get this sorted? I'm gonna try changing the regulator on my alternator that's all. Mine's a 1992 2.0 16v with a Bosch alterntor but I don't think it's the same regulator that you've linked. The one that matches my alternator is this one
