lowvr 0 Posted April 16, 2013 1999 T GOLF MK4 1.8T (20V TURBO) 5DR – RED Engine code: AGU MILES: 187k TAX: expired 28 feb 2013 MOT: 30th april 2013 FIRST REGISTERED: 27.5.1999 · Excellent runner, drives perfect · Suspension very tight and brakes well (due to many new parts) · Heated Recaro seats with immaculate interior (amazing for age and mileage!) · Bodywork is very good (all panels straight with good paint finish – small area of laquer peel on front passenger door) · 4 good tyres and a spare (all branded) · Lots of history! ( see pics) · Lots of new parts on engine hence drives great LAST SERVICE: Carried out on 4.8.12 · Oil service - new oil filter (genuine) - 4.3l oil (genuine quantum) - New sump nut and (genuine) · Pollen filter · Air filter · Engine bay detailed and regreased · Door hinges regreased · Brakes, steering and exhaust inspected. PREVIOUS SERVICES: · 12.10.99 11252miles vw priory park · 06.03.00 21441 “ · 14.06.00 29746 “ · 1.11.00 41009 “ · 31.01.01 50195 “ · 3.05.01 60000 “ · 18.9.01 70223 “ · 15.01.02 814218 “ · 04.11.02 90755 c.m services · Service manual notes to refere to invoices ( as written in service book) · 2.06.04 107984 · 01.04.05 115192 trust Volkswagen · 13.12.08 · 18.03.09 151478 manor garage · 03.09.09 · 06.02.2010 · 24.05.2010 · 19.04.2011 · 4.8.12 180k+ the services above that do not have mileage on them is because the previous owner did not note down the mileage but instead has only kept receipts of all the parts changed during services Significant/important new parts: 2011 & 2010 · New turbo and acuator · Reconditioned head · Cambelt change and water pum · New air mass meter · New n75 valve · throttle body hose · battery · pcv hoses and check valve · scuttle panel · coolant header tank · new windscreen · oil filler cap · water pipe · ribbed belt and vale cover gasket set · heater matrix · new recirc valve 2009 -2007 · antiroll bar bushes · head set + head gasket set · oil cooler · oil pump · battery · air con recharge · brakes discs + pads · brake hoses · coolant sensor· - water pipe · cambelt change at vw (150927) · + waterpump + tensioners + fan belt + antifreeze + service · Brake vacuum hose · Reverse light switch · Turbo oil line + coolant pipes + turbo hoses · Rear axel bushes · 2005 clutch + flywheel + many many many more receipts ….see photos PRICE: £900 LOCATION: leicester LE4 CONTACT: 07734931385 [/img] Quote Share this post Link to post Share on other sites
