delfinis38
which pagid pads for Mk4 rear calipers.
which pads should I be buying to fit mk4 rear calipers. it looks like pagid do 3 types for a VR6 2 that are 15mm thickness for early vin cars and a later set that's 17mm thick. my cars a N plate.
17mm and excludes wear warning contact
http://www.eurocarparts.com/ecp/c/Volkswagen_Corrado_2.9_1995/p/car-parts/brakes/brake-friction/brake-pad/?101440328&1&e2799815a881be68e4b5b743004b2839eda09627&000036
15mm and excludes wear warning contact.
http://www.eurocarparts.com/ecp/c/Volkswagen_Corrado_2.9_1995/p/car-parts/brakes/brake-friction/brake-pad/?101745378&1&cebd2a51f937efee5d5fcc9ca9cbbd71663fe9b4&000036
15mm and not prepared for wear indicator
http://www.eurocarparts.com/ecp/c/Volkswagen_Corrado_2.9_1995/p/car-parts/brakes/brake-friction/brake-pad/?101440198&1&695698b9b36ec127e6f620fcbb5f517ce7f4b0b7&000036
or does it mater ??? I'm hoping it the 17mm as they are cheaper £14 with 25%discount at the moment.
I believe the rear MK4 golf pads are 17mm to 17.2mm thick.
The early VR6 Corrado's had 15mm thick rear pads and the later one's had the 17mm thick pads,
so if your Corrado year is 1996 on a N reg then go for the 17mm thick pads.
Hope this helps.
Si :thumbleft:
