Carl&trish
Immobilizer
Hiya can anyone tell me if its possible disable the immobilizer on my vr6 without getting it plugged in as I'm in the middle of a conversion I've got it turning over but no spark or fuel ,
:bonk:
You can't but Stealth Racing may be able to send you a de-activated ECU in exchange for yours...
Ok cool will have a look
check to see if your relay 109 has not failed - this is for the ecu and will do just that: stop power to the sparks and injectors. About £15 from the dealer.
Also check the crank sensor on the front of the block.
Been out to the car and seems I don't have a 109 at all so gonna sort 1 tomorrow and see what happens ,
Thanx for info and will let you know how it goes
Just picked up 109 relay from vw but I don't think it's the right one its small and grey and only has 4 pins on it 3 large and 1 small , when I've look for relays for the vr they have all been large black relays ?
