bradv8 10 Posted June 4, 2013 hi ya hope ur all ok! right have put all my engine in and its running, im havin problems with the power gettin to some of the components the wipers dont work as there is no power getting to the fuse the blower doesnt work as there is no power getting to the fuse fog lights dont work! same reason electric mirrors dont work either for the same reason?? heated rear winscreen doesnt either? any one know why im not getting power to these components??? they all work if i run a +supply to them have changed the stalks on the steering wheel to as they all go through them but with no luck! have taken all the plugs out the back of the fuse box n put them back incase they wasnt conneted! but just cant find anything wrong!! is there a relay or something just for the power of these components?? headlights all work, dash lights, radio help please as want to get it moted next week! could it be the fuse box itself?? Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted June 4, 2013 What wiring have you swapped? Can you tell us about the conversion you have done other than G60. When i did mine in my Mk2 i only swapped the engine loom and did not touch the rest of the wiring and hence everything worked. Check you earths, perhaps you have knocked or disconnected some of them Quote Share this post Link to post Share on other sites
vw rule 19 Posted June 4, 2013 Hope this helps http://www.a2resource.com/electrical/CE2.html Quote Share this post Link to post Share on other sites
bradv8 10 Posted June 6, 2013 nice one for that cheers mate, has explained alot n what goes where!! Quote Share this post Link to post Share on other sites
vw rule 19 Posted June 6, 2013 No worries dude hope you get it all sorted. Si :thumbleft: Quote Share this post Link to post Share on other sites
