daveb142 10 Posted June 5, 2013 Hi there I'm currently at the beginning stage of starting a 20vt conversion on my corrado. I'm just wondering, what is the point in the metal power steering pipe that bolts through the front cross member? It looks as though it's a cooling pipe, however I don't see why the power steering fluid needs to be cooled? Was thinking of removing it and just running a straight pipe to the power steering pump. Then I could bolt the intercooler in front of the radiator. Would doing this cause any problems? Does the pipe need to be there? Cheers Dave Quote Share this post Link to post Share on other sites
wormy 0 Posted June 6, 2013 Yeah, it is a cooling pipe. The reason for cooling it, is that the power steering fluid is compressed quite a bit by the pump - up to 80-100 bar or so(?) - and that creates a bit of heat. :) Quote Share this post Link to post Share on other sites
marni 0 Posted June 6, 2013 hi mate what intercooler u useing and that pipe move it under so it gets air i cable tide to bumper the lower bit Quote Share this post Link to post Share on other sites
daveb142 10 Posted June 6, 2013 Ah right fair enough! Might do what Marni said and just move it down under the cross member then :) A toyosports one off of ebay when I get around to purchasing it! Cheers for your help guys! Quote Share this post Link to post Share on other sites
