shellmk2
g60 petrol in the oil help
hi i have petrol in my oil on a g60 and the car wont start
anyone have a idea on what it could be and the solution to fix it
i have done research on it and some say its the injectors and other say ecu
help needed as i would love to drive it
Petrol in the oil?
Surely it can only be head gasket or piston rings.
Compression test your engine if below about 6 bar on any of the cylinders I would go with piston rings.
Do you get oil in your coolant or vice versa?
As owen said, I'd take compression test on it..
Leaky injectors could also do this, so might be worth a check also.. Can't see how the ECU does this..?
