HummuH
G60 drive shaft/CV - bit of play
Hi all,
There's a bit of play, say 1cm or so on my passenger side drive shaft.
Is it likely that I only need to replace the CV joint or both shaft and CV?
If anyone has any pointers to where I can buy the best quality shafts and CV's that would be appreciated as I intend to replace both sides.
Thanks.
I would try to find which end ha the play in it.
Failing that replace both joints. The play should then stop
Thanks. May as well do both sides.
Any pointers to where I can buy decent inner and outer CV's?.
Ta.
AVS car parts have always done me well.
Search VW spares on google it will be one of the top options
