mayo6650
Corrado g60 running issues HELP NEEDED
My g60 seems to have developed a running issue happened three times now over the last month or so but doesn't happen every time I use it . Drive around 10 miles fine come back to car after couple of hours car starts and moves off but then revs die and have no power will not rev never cuts out don't let it but no power ,you can give it lots of little blips and get it above 2000 rpm and will drive but any lower and you have you mess around again . Help needed no smells of fuel or leaking vacuum pipes
still have same issue have checked wiring and tested coil appears correct have changed leads , plugs , dizzy cap and rotor arm but still the same and does it all the time now . HELP PLEASE BEFORE THERE IS ONE LESS G60 ON THE ROAD AS DOING MY HEAD IN.
