CrispyQ 10 Posted July 25, 2013 Hi all, lately ive been having a idle issue with my 2.0L 16V corrado it starts first time every time and will run and pull perfect as soon as you add even a tiny bit of gas but on tick over it has trouble keeping to one place also if sat in traffic for a longer than normal period of time with it on tick over the water and oil temp seem to get abit hotter than running temp but returns to normal once started to drive again. im not sure if the 9a engines have a idle stabilizer valve like the 1.8 16v which could have gotten blocked? or is the idle all done by vacuum pressure to the dizzy? I have also been told that it could be a oxygen sensor, just wondering if anybody else has had a problem like this and if so how they resolved it? Thanks guys Anthony Quote Share this post Link to post Share on other sites
easypops 8 Posted July 25, 2013 Hi, It's a subject that's been covered a lot Go to advanced search, it's above and right Type in 2.0 16v idle problem and you'll get plenty to read.......I'd have done it for you but only on my phone Oh and welcome btw :) Quote Share this post Link to post Share on other sites
guildmage 11 Posted July 25, 2013 (edited) And if you are still having problem searching go to your web browser and type this into URL address bar: site:the-corrado.net 2.0 16v iddle issue It will use google search to crawl this forum for answers you seek. Ps. I had problems with ISV in my valver but they were diif to yours my car would simply cut out. New ISV and problem is gone. Edited July 25, 2013 by guildmage Quote Share this post Link to post Share on other sites
Dollyman 10 Posted July 25, 2013 Yup, sounds like an ISV issue. I had that on my valver . Replaced the unit and its been fine since. Cheers Jeff Quote Share this post Link to post Share on other sites
Jim 2 Posted July 26, 2013 It's almost always the ISV. Swap that as step 1! Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted July 26, 2013 Also check all the air hoses thoroughly. Had similar prob once and it was a split on the underside of a hose. Very difficult to spot Quote Share this post Link to post Share on other sites
easypops 8 Posted July 26, 2013 Mine was a split wire inside the sheathing, for the throttle potentiometer , also very difficult to find.......which I found by pure luck :) Quote Share this post Link to post Share on other sites
CrispyQ 10 Posted July 26, 2013 thanks for the help guys Quote Share this post Link to post Share on other sites
rado mc 0 Posted July 26, 2013 Am i right in thinking the ISV can build up muck over time and a good clean and back on is also a good quick fix? Quote Share this post Link to post Share on other sites
Mawrick 0 Posted July 26, 2013 Am i right in thinking the ISV can build up muck over time and a good clean and back on is also a good quick fix? No guarantee - but yea that might help :) Quote Share this post Link to post Share on other sites
Jim 2 Posted July 26, 2013 Aye - certainly no harm in trying it before spending some money :) Quote Share this post Link to post Share on other sites
brettski 0 Posted July 26, 2013 I have the same problem so keep us posted Quote Share this post Link to post Share on other sites
