chopper666
brake fluid reservoir
Hi iam after the 3 braided blue hoses that go from the brake fluid reservoir onto the metal brake pipes any ideas where I would get them from as they are also metal crimped onto the brake pipes . Been too stealers and they are obsolete now so iam pretty stuck on where too get them from.
Cheers
Yer sorry mate it's a 93 vr6 . Ideally I want brand new pipes other then second hand I was wondering if any of yous have had too replace the pipes and where too get them from or the dimension and maybe I could get them made by a hydraulic shop
Thanks
pull one of them off and measure the ID, you can then get the equivalent size braided brake fluid/fuel rated hose + clamps from ebay,
Cheers chaps the inside diameter is 7mm and outside is 13mm. Spoke too a chap at Carlton hydraulics in Rotherham who can supply what I need
Much appreciated chaps
