big ben 10 Posted August 8, 2013 Hi guys So i have found my clutch on the floor recently, pulled it back up and it has been fine. But i was thinking of replacing the master/slave cylinders etc anyway. Bit of a look online and i see lots of talk of the master cylinders being obsolete, is it just the early models? VW came back with a price of Master cylinder is £167.72 incl of Vat Slave cylinder is £171.08 incl of Vat Regarding brake fluid you would only need about 2 litres which is £8.77 a litre Seems a bit expensive as i can get this slave? http://www.vwspares.co.uk/corrado_clutch.php for £46.50 Is there anywhere someone can recommend i buy these parts? And should i get the brake fluid from VW? Thanks Quote Share this post Link to post Share on other sites
dumptyboy 0 Posted August 8, 2013 I would recommend this slave cylinder: http://www.ebay.co.uk/itm/Clutch-Slave-Cylinder-VW-CORRADO-88-95-/370851216915?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorrado&hash=item5658747e13 And if you are fairly practical then remove the clutch master cylinder and strip it down, the seal closest to the spring inside is likely to be deformed and possibly causing your clutch problem. It's easy to strip down as long as you have circlip pliers, and be careful once the clip is removed as the spring inside is quite strong! I had to repair two clutch master cylinders recently and was trying for ages to get a replacement but couldn't find one anywhere! So I went to the car breakers yard and removed the clutch master cylinder off a B4 Passat (£4) and the internal seal is the same so I swapped the seals over and all is now working perfectly. Hope this helps you or anyone else with this problem. Quote Share this post Link to post Share on other sites
big ben 10 Posted August 9, 2013 thanks for the reply, much appreciated Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted August 9, 2013 http://www.vwspares.co.uk/product_info.php?products_id=1924 Got this on mine, over 2,000 miles so far all good for 40 quid. Quote Share this post Link to post Share on other sites
big ben 10 Posted August 13, 2013 ok thanks pete, good to know :) Quote Share this post Link to post Share on other sites
