bluerush1985
obd port?
hi, when i pull up the gearnob gaiter on the G60 i only have one plug with two wires, -brown and red, surely this is just the power to the obd port? where is the k and l lines?!?!
cheers
louis
Early cars don't have the fancy socket, I have an adapter to plug the White and Brown into a proper OBD for vagcom.
It was from my old 2.0 16v
Fiver plus postage if you want it?
but where is the actual signal for the obd port? i have an obd port to plug it up to but can only find the power and earth cheers hof, any idea where the signal wires (yellow and grey ones) are?
You possibly won't have them.
Plug the connector you have into the matching part on the reader cable.
A single connector will only give you abs fault codes.
Only very late 2+2 cars had ecu diagnostics.
If its a g60 the ecu part number should end in eg (that's assuming its the original ecu not a replacement)
