robrado974 1 Posted August 19, 2013 As above , will your Vr run fast from cold even if its been in the sun All day ? Or should it run at normal tick over ? Is this because the sender is sending the message that it does not need any air ? Rob Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted August 19, 2013 It's down to water temp. There is a blue temp sender on the coolant manifold which tells the ecu when the engine is up to temp. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 19, 2013 I replaced all three of these , a thousand miles back . So I'm right in saying that it won't always run fast ? Quote Share this post Link to post Share on other sites
Jim 2 Posted August 19, 2013 Even when mine has been sat in the baking sun for hours, it'll often still idle slightly higher than 'normal' for the first 20-30 seconds or so, before settling down to the normal VR6 idle speed. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 19, 2013 yes, usually at 1000rpm or just over for a short while, then drops down to normal idle speed. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 19, 2013 Thanks for replies , much appreciated . Rob . Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 22, 2013 It's down to water temp. There is a blue temp sender on the coolant manifold which tells the ecu when the engine is up to temp. Need to get my car on a vagcom I think . If it is the blue sender that's playing up , yeah it's no big deal to replace it but its only done 1500 miles . Quote Share this post Link to post Share on other sites
