paddy26 3 Posted August 29, 2013 Connector Outside Fusebox Inside Fusebox Color -30 30B, for fuel pump power Main Fusebox Battery Power Red -30B 30, for fuel pump power Fuel Pump Relay Input Red -Z1 Injector Power (1990+ 8v), inlet manifold pre-heat (carb) Fuel Pump/Glow Plug Relay Output Red/Black or Red/Yellow (gas) You can see the location of connections in the diagram on this page: http://www.a2resource.com/electrical/CE2.html My fusebox has 4 terminal connections in this location, instead of the 3 shown in the diagrams, but i'm not sure if there were ever any wires connected here. Can someone check on a 2.0 16v if these wires are connected in their fuse box? i may be missing a wiring loom! \Paddy Quote Share this post Link to post Share on other sites
paddy26 3 Posted August 29, 2013 Small update. I removed a fuse box from a mk3 golf SE this evening and it didn't have anything connected to 30, 30B or Z1. Also, there is a red adapter plugged into these connections, converting it from 3 to 4 connections. Looks like I'm not missing a loom after all. \Paddy Quote Share this post Link to post Share on other sites
