Dave W 0 Posted September 7, 2013 Ive just picked up a long stored car that wont start. Basic investigation reveals no feed to pump. fuse ok. Was wondering if there is any relays involved and if so what one, don't wont to start throwing money at it till I hear it going. Cheers , Dave. Quote Share this post Link to post Share on other sites
Sheppeydave1986 10 Posted September 7, 2013 Broken wire corroded terminals ignition ecu ignition switch could be a number of this:bonk: Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 7, 2013 (edited) Check out the fuel pump relay on the fuse board, no. 167, some other number sometimes also I can't remember, row on the right. Has two very large spade connectors, you can jump the large pins on the board with the relay out to check Edited September 7, 2013 by davidwort Quote Share this post Link to post Share on other sites
Dave W 0 Posted September 8, 2013 Thanks for that, will check out relay. Would it damage pump if you wired it straight off a battery to check it worked. Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 8, 2013 I'd disconnect the battery negative, remove the fp relay, jump the connections on the fuse board and connect the battery negative briefly to see if the pump runs first. Quote Share this post Link to post Share on other sites
Dave W 0 Posted September 12, 2013 Relay had it. Got two from breakers for a quid. Primer pump in tank runs but external one u/s. Every bit of it nla from vw. All on the bench at moment stripping it all down , very rusty. Hey Ho !!!!!. Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 12, 2013 I could never understand why they didn't protect it better under the car, so many parts of the k-jet under there, filter, accumulator, pump and housing and all those banjo fittings, at least they should have put a shield over it, my 8v just has a filter... Quote Share this post Link to post Share on other sites
Dave W 0 Posted September 13, 2013 She better go after I sort this lot out. Think car was driven along beach before being parked up for 8 years. Never seen such a crusty corrado underneath.Every thing that could sieze, has. Got two new rear back plates from vw though, bonus. Not many left in stock !!!. Quote Share this post Link to post Share on other sites
Dave W 0 Posted September 13, 2013 Never seen such a crusty corrado. Think it was driven along beach before being parked up !!. Got two new rear backplates from VW though, bonus. Not many left in stock. Think it was 17 left and 26 right. Quote Share this post Link to post Share on other sites
