Billzeebub
1995 Corrado VR6 £SOLD
-Registered on 06/01/95 at Wrexham Volkswagen.
-10 Previous Owners (though at least 2 of these were husband and wife)
-10 VW Stamps in the original service book; the last on 16/01/04 with receipt. All subsequent bills and receipts
-Every MOT since 2000, current certificate expires 24/05/14.
-car currently Sorned as of end of July 2013 (I own another classic green Corrado VR6!)
Specification:
It is pretty standard, Classic Green Pearl Paint with Heated Grey Leather Interior. The only modifications to standard spec are as follows..
-BMC CDA Induction Kit
-Coilovers fitted in lieu of standard Bilstein B4s (also supplied which have only done approx 10k miles)
-Rear Cup Holder (in lieu of Ashtray, which is also supplied)
-Lupo Wiper Upgrade & Headlight Loom Upgrade
-Laserline Cat 1 Remote Alarm System
-Sitek Battery Conditioner/Trickle Charger Supplied for storage purpose.
Major Work, With Receipts in Service History:
-Suspension Arm Bushes 03/04/07
-Bilstein B4 Shocks (x4) 27/04/07 @ 123,300 miles
-Rear Brake Discs & Pads & Bearings 06/05/08
-Major Service (inc the all important Rear Axle Bushes, Spark Plugs, Fuel Filter) £882.48 on 16/04/10 @ 131,879 miles
-New Bonnet Cable fitted 24/09/10
-External Repaint £940.00 on 26/11/10
-Replaced Heater Matrix for a new Valeo Unit & some minor Bodywork/rust Repairs £615.00 17/02/11
-Oil Cooler Seals replaced £172.96 on 14/03/11
-Laserline 213 (Thatcham Approved Cat 1 Alarm) £299 fitted on 08/04/11
-Wiring Work & Removal of old Alarm Wiring £108 on 21/04/11
-Major Service (inc ABS System refresh, Spark Plugs etc) £1103.28 on 11/01/12
-New Battery £108.00 on 21/04/11
-Clean & Adjust Brakes £109.80 on 22/05/12
-New ECU, ABS Work £339.00 on 25/05/12
-New AUX Belt, Aux Water Pump, Oil Pressure Switches, Breather Pipe & Oil Changed, Rear Brake Discs & Pads & Carriers replaced for OEM at a total of £988.94 on 12/06/13 @ 133699 miles
-BMC CDA Induction Kit fitted £193.32 on 13/06/13
-Alpine CDE 173BT Bluetooth/CD/Ipod HiFi (green illumination) fitted £149.99 on 12/06/13
There are 3 sets of keys with the car, 2 of which have remote alarm fobs. The Warning Triangle and First Aid Kit are still present in the rear armrest. There is also a spare set of Number plates provided as when I got the car I put Vw supplied Euro Style GB Number Plates on it. Wing Kirror Glass also recently replaced with blue tinted anti dazzle glass at a cost of £70!
GOOD POINTS:
-Bodywork in very nice condition with no dings, scrapes, scratches and most importantly No rust.
-Interior condition also very good. Headlining and Leather spotless with no marks or scuffs. Carpets clean and with fitted VW branded Carpet Mats in immaculate condition
-Comprehensive Service records and very good provenance from new.
-At least the last 3 owners members of CCGB/Corrado Forum and thousands spent.
-Long MOT May 2014).
-Starts and runs well with no over heating. Water Temp good and fans kick in as they should on all settings. Oil fresh and does not leak.
-although Sorn car is on a trickle charger so no problem starting, car gets started and run on private road behind property every week whilst off road.
-Electric Windows, Rear Spoiler, Wing Mirrors, Heated Seats and Trip Computer, Heated Rear Screen, Rear Wiper, Heater, Stereo, Instrument Illumination, Central Locking(off the remote), all work as they should.
-Space Saver Spare Wheel, Jack and Tools present.
-Vredestein SportTrac Tyres all round in virtually new condition (less than 3k relaxed miles since fitted). Speedline Alloys are also in outstanding condition.
-Original spec Shocks/Springs included if new owner wishes to return ride height to standard.
-ABS System Functions perfectly. The light comes on at start up and goes out immediately.
BAD POINTS:
-seems to be a slight engine misfire/hesitation at low revs/speed, drives fine at higher speeds with strong acceleration. Not investigated as have another VR6 which I am currently using. If I do not sell and decide to put car back on the road for winter I will look into this issue.
-Clutch Pedal feels stiff, maybe the Clutch is on the way out. No problem selecting gears and drives fine when on the move, but again at low revs or stationary it seems stiff?!
-some surface rust on robust suspension arm components, fuel tank straps etc under car.
-needs Tax as currently Sorn for last month
-Sunroof currently doesn't work on slide or tilt.
In summary the car looks really presentable and everything apart from the Sunroof works perfectly. I feel it probably needs some minor mechanical/engine bay work to make it an outstanding example. As someone without the knowledge of facilities to do mechanical work I feel somebody else could get a lot more out of the car than I currently am. It's a shame to see it sat idle and it's time for a new home.
I plan to Tax the car at the end of September and then run it over the winter months whilst my other VR is laid up. However, at the asking price I will put 6 months tax on it now.
£SOLD
Edited by Billzeebub
